Hi, having a solid extruded from a base profile made with lines and arcs. I also want to loft from that base profile to a second form.
But Loft doesn't work.
Searching around (**), it looks that the problem is likely that the 1st profile (the one made with lines and arcs) is not "combined"
-- and there is still no function to combine/ merge/ join the profile lines into a single one.
It is actually very difficoult to check point for point.
Quoting: (post 16 **) " So, some operations that require this connectivity to succeed (sketch offset, sweep path, etc) won't work correctly. But others, such as Extrude, are more forgiving."
I think this is a necessary feature (or the only "Fusion" will be in my head). Besides, I might be wrong. Thanks for suggestions
