Our editing window maxes out at 16Million lines of code. Many of mold high finishing is stepping over .003" It results in 30M lines of code. Theeditor is maxed out. Also while you are wainting to get your GCode, it would be wise to put a popup window that tells the user to chill out. I start clicking on things and can lock up the program every time. G-Code Stand by. Might be cool to put a meter that changes to show the % of completion. On this error, the workaround is to edit the code out at the mill.
Subject: CAM, Post Process, GCode Edits, Stand By Window While Post is Cranking
