Manufacture - Export a model from stock / remaining stock
We would like very much to be able to  create a body from remaining stock!
3 Comments
This would be incredibly helpful for anyone that does machining with multiple set-ups. I am constantly having to either model the stock, or use my imagination during cam simulations.
Recently the feature to preview multiple set-up at once has stopped working correctly too. Making this guessing game even more dangerous. The current simulation does not show the actual stock being removed during the second operation, so the cutter just appears to be moving through the remaining stock and I can't see what the actual part is looking like.
Considering how much time and material can be involved in projects like this, the feature would be well worth it.
RG_Productions
It would be nice, one work around is to select multiple setups before hitting the simulation button.
You can export remaining stock  to an .stl and then re-import as a new body.. Such is the workaround I chose.
Rest machining can get memory intense within single setups and force you into a different approach.
