Make "VariableName=10mm" define a variable ANYWHERE I can enter a dimension (exp
- It is SO lame and flow-breaking to jump out of a sketch, go to the Excel-like parameters windows and scroll and click around in there instead of just writing TubeDiamenter=10mm.
-> It imho ENCOURAGES bad design, because of these extra steps required. Thats the wrong incentive.
-> It would simply be the most efficient way to solve the variable assignment that I can imagine.
-> People will love it.
I think I would be relatively easy to implement. You already have a nice expression parser, just make it look for the "equals" sign and assign or reassign a variable on the fly. Come on fusion-dev-heros I know you can do it 🙂
- Make it a Preview beta (alpha) feature for pro users who know about it and know what they are doing
- You don't have have to add a user interface if you don't have time, just make it happen in the background
- Don't worry about the details for now, e.g. you can make it so that it simply reassigns the value if the name already exists etc (instead of adding a warning prompt in this scenario etc)
- You can even use a special charater for this assignment if "=" is a problem.
- Until you have time to create a proper user parameters-dialog, where I could see for example WHERE variables were assigned on the fly, you could just add the on-the-fly created variable name just as if it was manually created.
- The expression E.g. "TubeDiamenter=10mm" could just turn into TubeDiamenter after pressing enter, so you don't have to worry about keeping track of where the variable originated.
7 Comments
Bonus: It would be great if the fusion app-architecture was that flexible, that something like this could be achieved by an external extension/script/app. I guess scripts would have to be able to subscribe to all expressions being entered/used. Or maybe let users direct expressions to extensions by writing something like ExtensionName.TubeDiameter=10mm in an expression field, so that the extension can do its magic in the middle. I know. Dreaming.
PinRudolf
Would love this feature!
Also please check a similar request which is relatively recent. And a request from 2014 where the idea was actually accepted but has not yet been implemented.
ToddHarris7556
I'm spoiled by being primarily an Inventor user..... where this is the normal workflow. Switching over to Fusion (I bounce back and forth probably 6x/day), I always have to remind myself that I need to stop and define parameters first in Fusion. In fairness, I also get used to Fusion's autocomplete, which is very nice. I miss that when I switch back to IV.
davelois
I agree with your idea, but I would be even happy with a "half-step" to just leave the parameter window open at all times while I work.
mattsc
yes Yes YES!!! It is completely insane we can't do this already.
Is this really not implemented yet? I pre-declared about 20 variables only to later get deep into a sketch to realize I forgot one... "", fx= … there should really be a shortcut to declare a variable in the sketch.
This would be the best feature. I’m about to do a design and EVERYTHING is derived from the diameter of the piston.
