Make Copy and Paste feature Parametric and editable
As it seems copy and paste is not editable.
In my case a change to the design (just how something was split) makes the copy and paste command fail
which renders this command somewhat problematic to use in a parametric workflow.
Looks like an oversight by the developers.
Screen Shot 2017-08-31 at 9.42.22 AM.pngScreen Shot 2017-08-31 at 9.42.14 AM.png
1 Comment
TrippyLighting
Yes this was a misconception. See this thread.
The workaround presented only works in very specific cases.
For example if you copy/paste several items at the same time, but then want to remove something from the initial selection, that cannot be done. So you have to delete the copy//paste operation, which results in breaking subsequent operations.
