machining time: for patterns, folders and setups - show total time in browser
Hi all,
I really like the option to show the operation machining time in the browser ! A perfect and fast way to sanity check the machining time and detect typos in the feeds.
When working with patterns and folders, the fast sanity checking procedure does not work and always requires to right click the according folder/pattern and check the maching time explicitly. This is much slower and kind of inconvenient. Not good for fast comparisons between two setups or folders.
I use tend to use different folders in the same setup to compare different machining strategies or different pattern counts .... no matter what, a machining time total in the browser would be great addition.
VOTE if you like that idea !
Thanks for you support,
Stefan
this sum up machining time would be so helpfulthis sum up machining time would be so helpful
