Please improve the user workflow of "opening" downloaded Fusion360 archive & other file types.
Currently if I export an archive Fusion 360 file format .f3d and let others download and open it (double click file) they get an error message "Opening of local files is not supported!"
Can AutoDesk improve this by adding an option under the error message to upload and open the file? Or at a minimum look to add a hyperlink to the error message https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Err...
This would help users looking for an offline way of sharing files to still use Fusion 360 in a manner that is consistent with the Windows Explorer interface. So many new users learning Fusion 360 stumble over this simple workflow when we go to work on tutorial projects and class homework, as well as when working with others where we share files over web pages, email, dropbox and other non-AutoDesk cloud methods. Adding the support of upload and open instead of just an error message will help IMMENSELY!
Thank you for your consideration!
Stephen
Two by Four with quarter inch slot 1 inch deep v1.f3d
