Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
live / non-modal properties
Properties including Center of Mass and Moments of Inertia are useful but it should be possible to put them in a place where they're constantly visible, non-modal (user can do things while they're shown), and live-updated (push/pull/etc and they change dynamically)
4 Comments
TrippyLighting
Yep. In the olden Unix X-Window times you could pin about every window to the desktop if you wanted it to be there prmanently. Until cof course when you un-pinned it.
That simple idea has a lot of merit!
sgraves
I believe there is an existing approach to get this functionality.  Use an html window as shown in the Palette Sample code below.  One can do real time updates to the html using javascript events.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-F0068478-49F0-4E5E-9BAD-3116D8FCBCAF
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jpåÆ©ęŸ»é€šéŽ
