Let the user drag and drop a component "under" a new parent.
When re-parenting a component in the browser tree, you should be able to drag and drop the component into the spot where you want it to end up.  If I release the mouse where the blue line is in this picture, the component should become a child of the top-level node. Right now the blue line just misleads the user into thinking the component will be moved there, even though nothing happens.  The program currently requires the user to drop the component onto the parent node itself.
2 Comments
TrippyLighting
That can already be done and the functionality is pretty old.
You'll have to ignore the blue line and drag the component onto another component "name". Not sure that is clear.
Only works with the timeline marker at the very end (right).
ylevine
Ditto for dragging a body between components.
(Sometimes it works and sometimes it does not.)
This seem more like a bug than an actual feature!
