When one is parting off, almost every single time, you have to slow down rpm unless you want your part to fly and damage itself, lathe or worse...we have to manually adjust the g-code; then you go and adjust program in fusion and forget to manually adjust g-code again, and BOOM!
Bigger the parts, bigger the problems and risks.
Just adding an option (when programming part off) to set max rpm when certain diameter is reached, and lathe guys would be jumping in joy.
Simple update, but very important. This should ld be implemented from the beginning....
