Keeping Tools during Combine operation
When you're doing a Combine Join operation and you do NOT select to create a New Component from the combined bodies it makes sense to provide a Keep Tools option. The Target Body will itself get combined with the Tool Bodies, so that Target Body will of course get kept. The only question is whether or not you also want those Tool Bodies to be kept as is. So, "Keep Tools" is a sensible label for the keeping option.
But when you're doing a Combine Join operation and you do indeed select to create a New Component from the combined bodies  the "Keep" option not only applies to the Tool Bodies but ALSO to the TARGET Body. So, my suggestion, for the purposes of complete clarity as to what will indeed happen: When the user selects the New Component option, the label for the Keep option should CHANGE from simply "Keep Tools" to "Keep Target & Tools".
As it stands it not exactly clear what will happen to the Target Body. If you just "Keep Tools" will the Target Body disappear or will it also be kept as is?
