Interference detection between components and bodies
Thanks for the good work on Fusion so far.
we really need an interference detection tool that will check to see if any bodies or components are overlapping/interfering with each other.   This is a tool I use frequently in SWX.    My preference would be that we could run the interference detection, and then view each incident of interference.  interfering bodies should become transparent, and the interfering areas highlighted.
This is really essential when moving from the concept to prototype stage to avoid costly errors and re-work.
4 Comments
This exists in analysis tools (though it definitely needs more work)
madengineer13
Thanks Roambotics_Scott.
I feel pretty stupid for not finding that earlier.  🙂  Its fine for what I need now.
You're welcome but there's no reason to feel stupid there - if I were on the team, I'd take that as a sign that it's at least not as discoverable as it could/should be 🙂
keqingsong
Status changed to: RUG-jp審査通過
