Intelligent extrude feature
When I do a sketch and make an extrution, Fusion works fine. But when I edit the sketch (the video below) the extrution stays as the previous stage. I think, an intellignet extrution, which extrudes automatically the same height as the first sketch can be very helpfull.
https://youtu.be/Uy9dMbb4liI
3 Comments
HughesTooling
I can't see your video but I'll take a guess. Fusion's sketches don't work the same as the ones in most solid modelers, they allow you to select parts of the sketch that are closed regions, you don't have to extrude the whole sketch. Also you can have one sketch and use the closed regions for more than one extrusion.
Take this simple example where I've used one sketch for the box, bosses and holes, if I add another circle to the sketch how are the extrusions going to know what to do with it. If you add a feature to the sketch you need to edit the extrusion and select or reselect the regions to extrude.
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
