Intelligent dynamic tolerances
In the classical CAD days the end product of a 3D model in cad often was a set of 2D drawings with the tolerances noted somewhere on it.
However in the age of 3D printing the 3D model itself is the end product. Right now the only way to have hole tolerances is to actually 'hardcode' them in by not model something nominal, but model it with the proper tolerance. This seems rather clunky if you ask me, what if someone 3D printed something with plastic and wanted the end product to be in steel, would he remodel the whole thing with different tolerances?
I opt for a way of assigning tolerances to holes, and where this tolerance will actually be in the 3D model and you can change easily. And if you would export the 3D model to a STL file for printing, the tolerances get included. This way you don't have to manually 'hardcode' every tolerance in.
3 Comments
Here a video where I indirectly refer to; the practice for 3D printing in this video seems to be to 'hardcode' the tolerances in terms of offset in the model.
PinRudolf
Hi Mathijs,
I agree with your statement, 3D tolerances are a must have for modern manufacturing processes. I dare even say it is as essential for CAM as it is for 3D printing. (Though in this case mostly to prevent errors on the manufacturing side)
I have posted a similar idea before where I suggest to add this option in the parameters menu. Though I can imagine that resulting in confusion for the quick and dirty developers.
Susan002
Totally want this for CAM.  With complex component interactions, it is way too clunky and time consuming  to have to manipulate the surfaces to create the desired fit tolerances .
