Insert McMaster Carr window initial size & navigation
A small quality of life improvement idea.  When you click on the insert McMaster Carr component option, the window that comes up is always the default size which is horribly small on my 4k monitor.  I have to resized it every time I want to use it.  It would be nice if this browser window remembered the last size it was during the current session.
The browser also desperately needs a back and forward navigation button at the very least.  You used to be able to right click and a menu with a "back" option would appear but in the latest releases that was taken away.
I know these are not ground breaking ideas but it would save me from making an annoyed groan everytime I use this functionality.
4 Comments
sanket223.patil
Yes , Agree with This .
melvinbrian3d
I Agree Too!! Voted
untrustedone
All windows should be remembered.
Both of these please.
Resizing the window each time is annoying. I'd also like to be able to resize the window (and others, like the sketch palette) by dragging any edge, not just the bottom right corner.
The McMaster-Carr catalog needs a browser back button at bare minimum, or add a navigation trail across the top like Explorer in Windows, so you can click on a category a few steps back, eg "McMaster-Carr > Fastening & Joining > Screws & Bolts > Socket Head Screws > Low-Profile Socket Head Screws > Metric Alloy Steel Low-Profile Socket Head Screws" and then click on "Screws & Bolts" and choose a different branch without starting from the beginning.
