Show only
Search instead for
I agree. We will be looking at redoing some of the tool library information in the future and I'll keep your suggestion. Just 1 point, I believe some Face Mills specify the side angle of the insert. But as long as we illustrate it properly, it shouldn't be a problem.
I disagree that the illustration will show the difference to all. Compare a 45 angle to a 50. They can look the same to some. Then there is bound to be some odd special angle someone uses.
I would not depend on that illustration keeping people out of trouble.
If you don't want to mess with and potentially mess up the math just put a little text above that field like Included angle or 1/2 included angle.
