Improvements to the Measure tool
I feel like these would be some simple and straightforward enhancements to the inspection tool:
- If you measure a filet in a STEP file it doesn't give you the radius, only the line length. Not very helpful.
- Measuring between lines gives you the distance between the points you select, but that isn't necessarily the normal distance. Selecting two lines should give the normal distance between them (i.e. measuring thicknesses and lines are // but not directly in line vertically)
- XYZ differences would also be nice
The inspection tool is underrated but is used extensively in reverse engineering and quoting machining jobs
Thanks.
2 Comments
HughesTooling
A few of the things you're asking for already work. Measuring between 2 lines does need improving as it only gives the distance between the 2, if you can measure between 2 points you also get the XYZ distances. I guess were it sort of fails is if the 2 lines are different lengths but you can get YZ picking 2 points on the line.
Distance between line and point.
Distance between 2 points
I don't know why you can't measure fillets the model I'm using in the post in an imported stp file and I have no problems measuring the radius of an edge or a surface.
Mark
@AnonymousDepending on the generating system, the reason the STEP's radii won't give you a radial measurement is because they're not actually true radius/fillets. It's been a common problem for a many years and by no means restricted to Fusion.
