Whenever a design has a pending edit to be saved, there is a small * asterisk next to the name in the design tab. This tells me that there is a pending change that needs to be saved and synced to the cloud storage.
In addition to this visual clue, I'd like to see another icon that shows whether or not a recovery or "auto-save" version has been created in the recovery directory (locally). It could be a separate icon like my doctored image below... Or perhaps the asterisk could be colored red or green to indicate that there is a save pending to cloud storage, but also indicate the status of a recovery version at the same time.
With this visual cue it would also help to clear up if a manual recovery save (Mac: Command + Shift + S or Windows: CTRL + SHIFT + S) was successful or performed recently.
In addition to this visual cue of an existing recovery document, I believe it would be better to not remove recovery files when Fusion is shut down or a design is closed. I think a successful save to the cloud should be perhaps the only exception to this.
Instead, I would propose a time based system that would leave recovery files in the recovery directory for a period of time specified by the preferences or by preference setting that determines the maximum amount of disk space that the recovery directory should use.
This request is based on numerous discussions I've encountered in the forum.
I believe these two things or at least one of them things would reduce confusion around the "auto-save" functionality in Fusion 360 in a big way.
Thanks for voting this Idea up if you like this suggestion!
