Improved Customisation of Title Block in Drawing
One of the features I loved on Solidworks drawings was the ability to change the headings and properties displayed in the title block.
At the moment you can edit attributes but these are predetermined and locked. Different countries have different standards and different practices for drawing title blocks. I understand you can now import your own templates. What would be nice is the ability to open the title block attributes panel and select from a list what each one could be. Instead of being locked to specific ones. The ability to choose from a projects properties, such as material, weight, cost, SCALE (I Actually can't believe that SCALE is not one of the properties listed in the title block) would make drawings that much better. At the moment I have to export as a PDF and then redo them all in adobe illustrator.
1 Comment
jameseanderson
Ps. Also the ability to add the drawing projection icon would also be good. Third Angle Projection, First angle projection, etc. All things that would be nice to be able to put into the title block within fusion. 🙂
