Hi everyone,
I'm a bit stuck in the thread milling capabilities within Fusion. I've already asked in the CAM section for help, but there doesn't seem to be a solution ready. (http://forums.autodesk.com/t5/computer-aided-machining-cam/drill-point-thread-mill-programming/m-p/6...)
When thread milling, fusion is always looking at the diameter of the modeled hole, and an offset is possible. This however isn't working well when sometimes holes are sized differently. An m10 hole can be 8.5 mm (standard drill size) or 8.376 mm (the minor diameter) or simply 10 mm.
What i would really like some more control over how a hole should be thread milled.
Regardless of the hole size, or even a point should be enough to thread mill.
We need a few things:
The use of the cutter in this video would be great, 4 seconds for a completed M10 hole!
http://www.johs-boss.de/en/products/thread-milling-cutters/bgf/
And also you can download their programming tool from here http://www.johs-boss.de/en/products/thread-milling-cutters/bgf/
