Improve the Readability of Version Descriptions
I would like to be able to read the entire Description of the many Versions of my part. The description is sometimes the only place that has valuable notes differentiating versions. Unfortunately, if it is too long it just gets cut-off. The web browser Fusion-Home lets you read the Version Description well, but the Fusion 360 interface lacks a good solution to do the same.
Idea 1: While on Fusion 360 Data Panel, showing all of your Versions for the part you are interested in, the user can click on the description and it will expand so you read it all.
Idea 2: While on Fusion 360 Data Panel, showing all of your Versions for the part you are interested in, the user can click on an icon to read the entire description of the version. The icon would show up just like the Promote (Up Arrow-Icon) and the Open (Folder-Icon).
1 Comment
Either of these two options would work for me, as long as the result is text I can copy and paste elsewhere. The web view and F360 view are synchronised now, which just means they're both truncated at the same place. I (used to) use the version description as a place to add notes on what's been changed between versions, but it's no good to me if I can't see all the notes or use them elsewhere, so now I'm going through all the parts in my design and trying to put together a spreadsheet of what changes were made where. Not the best way to do this.
