Improve the error handling of inpossebul high values - set it to max instead of
improve the error handling,  when you drag the arrow to long and the value gets to high let the max possible number stayin instead of error "0"
4 Comments
When i think about it a snap will be a better solution, smalle snap and maybe a highlighting color indicator, when the snap taken place:
Must be able to set the user step to shift arrows: 10 mm,1 mm, 0.1 mm, or set by the user, for example 0.025 mm. This will enable accurately and precisely move the arrow where you can quite finely controlled.
I agree with harvid22 about snap geometry.
