Improve NGON and better poly to TS conversion
It looks like Fusion has problems with NGONs a lot.
This is a pretty simple model, a cylinder like shape with an NGON cap.
It seems that I need to further create a planar insert geometry to stabalize the surface flow and then cap the opening.
Otherwise Fusion works quite a long time on the OBJ to TS conversion and procuses also bad geometry.
Here are the Fusion results:
NGON is filled with crazy subdivisions and turned into triangles
I would need to remove the edges to rebuild the ngon
you dont want to have to open the file and patch in a filler.
2 Comments
cekuhnen
Any update from the Fusion team regarding this?
The current version of Fusion still has problems with NGON obj imports!
brianrepp
Status changed to: RUG-jp審査通過
