Improve 3D sketching move vertex handle Interface
Here is a screencast outlining the problem and inefficiency I experience with the 3D sketch tool.
If I create a sketch in 2d top view I can click a point and move it nicely by dragging it.
However to move a point up I need to use the move command.
In addition the handles from top view will look flat from a side view.
I cannot click drag anything and the 3D sketch environment feels extremely slow and complicated
to use. It is quite painful to be honest.
https://drive.google.com/file/d/0Byzv_NlyKp_2akdPbFFoZGF3QW8/edit?usp=sharing
Proposal: when I switch into a side view I want to see the side grid as well.
In addition when I switch to a different view the inferface should be as easy to select and move like in view I created the sketch in!
1 Comment
keqingsong
Status changed to: RUG-jp審査通過
