Import png, jpg and/or SVG as contour to extrude
Pngs or jpgs and/or SVG as Logos or names could be imported to Fusion 360, and be use in Grayscale as closed contours, so it could be extruded into an object's face
5 Comments
I was thinking again about my idea and I think, The range of formats, used to transform to a polyline/contour coud be the dwg format (from Autodesk itself) too! A better integration with the other Autodesk products will be amazing.
Importing png would be brilliant. Just trying to find a way to have my rather complex QR code imported so I can 3d print it. For the time being, I am waiting on the results of the conversion from png to svg to https://convertio.co
Is maybe possible in illustrator rasterize the png file and then convert it to a svg file. Actually i find a way to use reagularly contours from svgs into my design and extrude it on a surface 🙂
colin.smith
Unfortunately this idea did not get the support of the community and as such we will not be pursuing it. Please feel free to rework and resubmit this one down the road. Thanks for taking the time to submit your idea. Due to the low strategic fit, we have decided that we will not be pursuing this one at the given moment.
colin.smith
Status changed to: RUG-jp審査通過
