Import cad data into where ever a user wants for real man
Fusion can load a local STEP to make a new design
Fusion cannot insert a local STEP file in an existing design
Fusion cannot insert a cloud STEP file into an existing design
Fusion can insert a cloud design in a new design
Fusion cannot insert a cloud design into a base feature in a new design
Fusion cannot insert a cloud STEP into a base feature in a new design
I know nobody that uses DXF - I never even came across a person in industrial design.
We use STEP!
I have to say I am stunned that after years of asking for better data import Fusion is still the
only application that fails at offering those must have structural tools and functions.
8 Comments
Please, please, please make this work locally
Let me drop a .step into a design, import, and insert without having to upload it to the cloud first
DXF is used extensively in the 2D cutting space: laser, plasma, waterjet cutting.
I do use DXF and many others like me: it's the to-go format for laser cutting. I also use STEP for 3D printing and milling.
cekuhnen
@Anonymous @SeanMurphyADSK
You use DXF for 2D work - I am talking about 3D models.
Yes DXF I use for the laser cutter myself. I did a change to the text that was not saved
because I realized after writing that the DXF import is only working for 2D drawings in sketches
and not DXF as a 3D model.
Most of us in the design world have to deal with models from many other software platforms.
Data import/export really really really matters
colin.smith
Status changed to: オートデスク今後検討
@cekuhnen I was replying to your statement "I know nobody that uses DXF", now you know one. So, while I understand the request to improve or expand import capabilities I'm totally against dropping DXF because I DO NEED IT and is one reason why I do use Fusion360.
On top of that, nowhere in your initial post you mentioned 3D models, but that might just have slipped away, no problem.
cekuhnen
@Anonymous
as mentioned I am revering to 3D models - of course do I use DXF for 2d work.
sadly this forum does not allow editing of initial posts so I was not able to corret
it after I noticed the mistake that insert refers only to 2d files.
