Import and edit curves wire
There is a need to import curves from a step file and then to edit them. It is necessary to construct the model geometry in Fusion 360.
Why when you create a new file from step, Fusion 360 does not import the curves of the wires that are in the step file?
Why the extracted curves taken by the instrument "Include 3V geometry" can not be edit, where CV points how to modify the curve?
Add the ability to edit and modify a curve by points, otherwise it is impossible to work normally.
3 Comments
HughesTooling
What progame is the image at the bottom from.
Thanks Mark
To HughesTooling:
This is a screenshot of Moi 3D. But the same thing in Rhino, Solidthinking Evolve, CATIA, NX, the principle is always the same – to edit the curve, we need the vertices of the control curve, for this reason, in systems where there is a normal modeling, has the tools to edit any curve, even imported.
Attached screenshots from other systems, in which I imported a curve through step file:
Yes Please!
I would like to see more support for editing imported curves. Just like the majority of other software is capable. Until 360 is the only game in town Autodesk needs to play more nice with other CAD/Illustration/Design file formats.
Please.
