This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Import 3D dxf
Import 3D dxf
Please add support for importing 3D dxf. Not just 2D.
3 Comments
HughesTooling
You can import 3d DXF\DWG file using the data panel in Fusion. In a project just click the upload button then select your file.
mark
rezabek.blaz
I tried this but its import, just three lines. SW imported this file with 30 splines.
HughesTooling
Well that is a bug and you should post an example in the support forum so AutoDesk can fix it.
Mark
