Show only
Search instead for
Hold shift to constrain horizontal/vertical dragging of sketch element
I'd like to be able to hold SHIFT whild dragging a sketch elelement to contrain the dragging motion. Not to be confuse with adding a horizontal/vertical constraint.
Thank you for your idea, this idea is getting archived due to the nature in which we use modifier keys. Holding shift already is used to rotate a model and since there are users that like to sketch in 3D removing this ability to add the function in your idea would cause confusion.
