Hide joints and sketches for whole document
In larger assemblies with distributed designs I often have the Issue that my model looks too cluttered. Mostly because there are some sketches turned on and the most joints are visible.
To hide everything it takes quite some time to go through all designs and hide everything.
And if I need some sketches or joints later I need to manually find them again.
I would suggest having a toggle option in the document settings for hide all joints and hide all sketches so that you can quickly switch.
2 Comments
jeff_strater
Status changed to: Gathering Support
you can do this here, today:
Is that sufficient, or are you asking for something else?
florian.b
Thats perfect. Just didn't expected it there. But somewhere in the browser since usually you go there for hiding and showing things. Thanks
