Have CAM check for collisions when doing retracts and moves.
If you have a tall feature on a part, and the CAM is moving the tool during a retract - the tool may not retract far enough to miss the tall feature and hit and cut the feature where you don't want it, costing you a piece of stock to redo the part.  Maybe add some code to adaptively set G64 Pxxx or handle retracts using G60 which I believe does not go through predictive path code.
3 Comments
Can you explain a bit more?
Maybe add a screenshot?(Or code?)
keqingsong
Thank you for posting your idea! The idea is now 2 years old and does not have many votes, so we are going to archive it. If this is still important to you, please make a new post with the idea included. You can follow the idea submission guidelines here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
