Generative Design: Add simplify like in simulation
Add simplify, for each study. This way when working in an assembly I can import the components/bodies important for that specific study - instead of having to turn them off and on globally.
I realise that assigning them to obstacles/preserve regions sorts them into individual studies, but it's still a little frustrating forming new studies based off components when you already have existing ones.
5 Comments
I_Forge_KC
This is already there. Instead of being called simplify the button says edit. You can clone various setup models, make new ones, create unique obstacles/preserves/starting shapes, etc.
esumft
I realise this, my point was more towards making a "study" act more like a component. Store all the geometry I create in "Edit Model" in the activated study, instead of a global "Model Components" folder. This is so much neater than me hiding/showing components I think might be relevant, and my custom obstructions/preserves.
Or is there a way I can create a new generative model? No obvious selection.
esumft
So actually what I want is the ability to create a new "Generative Model" as above. Seems strange to have a parent that can't be duplicated or create a new one?
I_Forge_KC
You can. In the edit environment you can make clones (or entirely new) models.
For your specific ask you would create a new model for each study.
esumft
I see, thanks. I still think that's not a great UI feature - rather that option was in the work space.
