Fusion 360 for 3D printing
Please make an easy way to import .STL files to Fusion 360.
Current workaround (https://www.youtube.com/watch?v=Fef_Y3Czkp8&lc=z132ejcgmrmlxv35l04ce1wrvrnadzvbgw00k.149883958360902...)
looks like this application is in stone age.
1 Comment
pnboyer
I use Fusion 360 to create .stl files for models that I intend to produce on my 3D printer.  I have had a large number of these models unable to be completed.  These models, when stopped by the printer, are stopped because the printer uncovers an "error in the file".  After quite a bit of research I am led to the understanding that there are services available that "repair" .stl files.  Since all my models are produced using .stl files produced by Fusion 360 I had some .stl files "repaired" that I had been unable to produce with the 3D printer.  Once I attempted to produce the models using the "repaired" .stl files, I discovered they COULD be produced!  This brings into question "Why would Autodesk produce software that generated errors in its .stl files?"
Peter Boyer
