Fusion 360 Administrative Installs
Just wondering if this can get some traction from the Autodesk team.  I'd like to see some improvements be done with the Fusion 360 Admin Installer.  It is a pain to deal with as a Systems Administrator.  Can we get them in MSI format to allow for easy installs and updates?  Otherwise, it would be nice to be able to specify an auto-update mechanism or allow for the installer switch to be something like '--install --update' and it does one of those, or both of those, depending on the state of the machine.
Right now you have to ensure it is installed on the machine and then run an update Package over it.  If the machine doesn't have it, it'll fail, if the machine has it and you push the package for '--install' it'll fail.  It's just not a very good mechanism for managed environments.
Thanks for your consideration!
