Fully Rendered (cloud-based) animation
Being able to save an animation/video in which each frame is fully rendered. (Unless I'm wrong - "renders" are single-frame only, and "animations" are simple-shaded frames).
This could take a long time (and a lot of CPU cycles) to generate such a video (which is why people like Pixar use Render Farms) - so - what better feature to leverage cloud computing for?
In addition (should probably be a separate thing - but a tiny one) - threads which are NOT "modeled" should behave as if they are for the purposes of rendering (and animating, in the context of this request).
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
