Folders for Canvases
I have a design with maybe 70 attached canvases and it can be quite a trick to manage all of them.  My workflow involves uploaded calibrated images of items and then viewing several at a time, overlaid in the same location, to size accessories designed to work with multiple photographed items.   The ability to put these in folders by certain categories would be very helpful in managing them.
2 Comments
HughesTooling
Don't know your workflow but are you using components in your designs. Canvases imported with a component active will be contained in that component. I guess you could even make components that have no model information just to organize your canvases.
Mark
SGL-Design
Thanks for the suggestion Mark, I do that on many designs and use components heavily to keep things organized, however in this case I put the canvases all at the top level because every component in the design may at some point be referenced to any canvas.    Many other aspects of a design can be put into folders, so it seems like a simple extension for canvases.
