Show only
Search instead for
@Igorva You can see difference then You choose type "distance and angle" and set the angle to something other than 45 degrees.
Then we have two problems: 1. You need to specify the exact size from the edge, therefore the direction needs to be changed. 2. If you have several edges, then each edge can set a chamfer in a different direction, and I can not change it. I will have to do a few features to adjust the direction with an angle, but this is stupid.
There is no difference if the angle is 45 degrees.
It is very useful for unequal distance chamfers and angle distance chamfers. I appreciate it because it feels trouble while I dont get exactly what I'm looking for and in a hurry. I had to do it again. So a reverse option is very preferable here.
