FLIP command in Sketch mode
In the Sketch mode, please add a command to FLIP selected sketch entities in either a horizontal and/or vertical way, instead of using the Mirror command. This feature has been in illustration software (Freehand, Illustrator) since 1988 and is widely used and very useful. Thank you.
3 Comments
Yes, this would be very helpful.  I designed a part backward, and now need to mirror without copying to fix it...  Instead I have to manually move line and arc endpoints in order to maintain downstream sketch association.
custom.discoveries
Yes having flip command(s)  liken to PowerPoint and Visio (flip Vertical, flip Horizontal) would be very helpful on both Sketch and Objects.  Yes, I understand you can perform this functionally through the move command, however, the move command requires you to find the center point of the object to "flip in place."  If you don't get the center point exactly, the flip will be off set from the original position.
Groterhooge
Fusion 360 Team, please. It's relevent even now. Add this tool. Also agree with a @custom.discoveries
