Fixture avoidance
Fixture avoidance
It is nice that Fusion can tell you you've hit your fixture. But it would be much, much better if Fusion could not hit the fixture in the first place.
Would it be possible to have Fusion take fixtures into account when calculating 3D passes?
7 Comments
Havent used the CAM part of Fusion much yet, but the other day I watched this video from the Fusion team on youtube that mentions 'touch surfaces' where he selects particular parts of the geometry to avoid. I don't know if this is available in all machining operations..
https://youtu.be/DezTxhHQua8?t=2m3s
I don't know if this is what you meant, but perhaps good to know anyway.
Niels
promm
Status changed to: Gathering Support
al.whatmough
This is a common request and something that we plan to add.
In the mean time, if you define your fixtures as "model Geometry" then the toolpath will avoid them.
colin.smith
Tbaker25
Hm. You mean in a toolpath, under Geometry > Model Surfaces you add the fixture surfaces? Won't that try to mill those surfaces?
al.whatmough
It will only try to mill them if there is stock there (provided rest machining is turning on as well
Tbaker25
I see what you mean.
