Fix that View Cube
Fix that View Cube
OK, I don't have a "middle mouse button" I use a trackball which for me is WAY better for modeling than a regular mouse.
Issue is rotating views and such. I use the goofy block up in in left corner a lot.. which is fine but, it's so close to the edge for the window when rotating the pointer ends up off the window and the rotation goes in to freakout mode.  Would like to be able to drag/relocate the block/cube to a diff place or at least move in a bit so it an be used a little easier.
3 Comments
t_lamourine
umm said "left side" it's actually on the right... opps
schneik-adsk
does you trackball have three buttons? Why not use shift plus middle button?
t_lamourine
again, no middle button.. left button an right button only. and have multiple finger injuries where the one button at my thumb is really the only one I can use "positively"   there are actually 4 buttons (Kensington turbo mouse) but again.. only the one thumb button is really usable.  and I hate mouse/keyboard combos, mostly because I'm old and can't remember them. 😉
