Fix shaded with hidden edges visual style to show holes
I would like to see the vertical lines added to better represent the hidden geometry in the shaded with hidden edges view as they do in the wireframe with hidden edges view. When using the shaded with hidden edges visual style the vertical lines of a hole are not shown, instead just the circle at the top and bottom surface of the hole are shown. Specifically, this occurs with any hole with curved sides (circle, ellipse, spline, etc.). The only lines that show are corners from a square / poly or at the joint of multiple splines. These lines show up in inventor pro 2016 in the shaded with hidden edges view style, I would like to see this fixed in fusion 360 to act the same. I've attached a few screenshots of a similar part in inventor and in fusion 360 to illustrate what I'm talking about.
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
