Fix Set view as Home command
In Fusion 360... when I click set view as home command, it will have either 'Fixed Distance' or 'Fit to View' selected with a little check mark beside it. This means that if I want to actually set the view as a new home position and 'Fit to View', I need to switch it to 'Fixed Distance' and then back to 'Fit to View'. Clicking 'Reset Home' doesn't take my current angle as my new home position (at least for the thumbnail is doesn't).
In Inventor... when I click set view as home, nothing is already pre-selected; so I can actually just set my new home view in either a fixed distance or fit to view.
Proposal: Get rid of the pre-selected command on the set view as home and make it work like the way it does in Inventor.
