Shocked that Fusion360 doesn’t handle this. Please please please add the ability for fusion to fix gaps and areas that might have overlapping lines. Various hacks out there - connect the dots, gap finder etc.. the fusion360 product obviously knows when a profile isn’t closed so code should be there to correct it. Some of us are using digital tracing boards and don’t have the granularity of fusion to see the gaps (I had one in a drawing at .0005 ! ) didn’t even know it was there.. this is a common problem as I have found it all over the web with people struggling with it. Maybe an out of the box idea would to not only make a fix button that allows user to set tolerances but also be able to set fusion as a whole to “not “ be so precise? I know sounds counterintuitive but in some cases . 0005 precision just isn’t needed .. honestly this problem is preventing me from moving forward with fusion and I would really like to - had I not stumbled on this I would have probably purchased fusion at the 40% discount today. Anyway, please fix this issue - it will save many users countless headaches and time, I personally have spent days looking for a solution and still stuck. Thanks for listening
