Fitting table for technical drawing section in Fusion 360
Creating technical drawings which are conforming to standards is an essential thing for production,ERP/SAP and is the last confirmed document. There are some features in Fusion 360 missing, like fitting tables.
To create a technical drawing for manufacturing you need to make clear where fittings are needed and which tolerances are given.
Below you can see an example for such a fitting table that is conforming to standards.
What is needed in a fitting table?
Explained at the fitting 6,5 H6:
At first we need the fitting type itself like "H6"
Then we need the field of tolerance like +0,009 - 0
In the end we need the minimum and maximum value like 6,509mm and 6,500mm
Example of fitting table for Fusion 360Example of fitting table for Fusion 360
Cheers
Chris
