Sometimes while working, whether it was in a sketch, patch or modeling, for some reason a command would take 5 minutes or more to be calculated. And that would affect the rest of the design. The whole assembly becomes very sluggish.
For example, I just created a new sketch and projected some geometry into it. Then I tried to offset that geometry and it took literally 5 minutes to create what I thought was a simple rectangle. After looking into it, there was a problem with the bodies being projected. Usually if I continue with this design the rest of the design process becomes very sluggish and every time I want to do a sketch or model a body it will be slow as well.
I suggest if it is possible to add a feature that shows every command and how much time/resources/size it is taking. That way we can optimize our assemblies and make it easier for us who don't own a super computer. Also we will be able to recognize more what "ticks" Fusion 360 and makes him mad, just so the next time we would stay friends without any "miscommunication"!
Thank you!
