Find dependent dimension
If I try to delete a dimension that's being used somewhere else, I get this warning:
"This dimension is referenced by a parameter in an equation.  Are you sure you want to delete"
I would like to see a feature that tells me where it's being referenced.  This can be hard to figure out.  Either a button on the warning dialog box that opens up a window listing where it's being used, or a list right in the dialog box.
Similarly, I'd like to be able to open the Parameters Window and search.  Search on a number, dimension ID (d234), parameter name, comment end feature name ("Extrude1").
