Filter parameter list
Hi.
I work as a professional product developer and use Fusion360 for many many hours every day.
Lately, I have started using the parameters list in Fusion a lot!  It's very very nice to use when the design is not set yet, so I can easily and fast change parts of the design.
BUT, when the model contains a lot of parameters it takes too much time scrolling for the right parameter to change.
It would have been so brilliant with a filter function in the parameters list!!! That would have made my day so much more efficient. Please consider this option fast. It should not be a difficult and time-consuming task to add a filter function.
thanks in advance 🙂
2 Comments
oyvindTMNSU
@TimeraAutodesk as I saw in another thread I was a part of, that you are project manager for drawing I just tag you here 🙂 I think this can be a quick fix that can be done fast 🙂
I know there is possible to add parameters to favorites, but if you add a lot of them you have the same issue.
I'm thinking of a search bar or something in the right top corner of the parameters window.
oyvindTMNSU
Also, it would be nice to be able to have the parameters window open while working. So you could just drag it to a second screen and always have access while working.
