Feature request: Unlinking 3D object in matrix (e.g. RECTANGULAR) Pattern
This feature request arises from this discussion:
http://forums.autodesk.com/t5/design-validate-document/unlinking-3d-object-rectangular-pattern/m-p/6...
Here is a use case:
1) Create a 3D object.
2) Create a matrix pattern of this object, e.g. 10 x 10 matrix rectangular pattern
Objects in this matrix is automatically linked at creating time,
meaning if you change one of them (e.g. the reference object)
the changes propagate to all of them.
3) Now unlink all the 3D objects in this matrix of rectangular pattern.
When this rectangular pattern is unlinked, each object can be edited (moved, re-sized, cut,...)
independent of other objects.
Meaning its changes does not propagate to other objects that are also now unlinked.
This feature is not currently available.
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
