Show only
Search instead for
I frequently machine round objects and would prefer a circular or spiral facing pattern option. both for looks and it would be faster. any suggestions?
This is a question you should have put in the CAM section. You can use an adaptive cut to get spiral facing. I think I've used a 3d option in the past, just make sure the top height is set above the face you want to machine.
