Face Milling Improvements
- Even stepdown box to select for Face Milling when using multiple depths.
- 'Spiral' cutting strategy when Face Milling in Climb or Conventional direction, so that the tool doesn't lift and rapid from one side of the job to the other between cuts to maintain cutting direction with multiple passes.
2 Comments
ktrneill
Also in the 2D Adaptive this would be good
Jon_Bancroft
I used the "spiral" technique in other CAM software. Currently when I select Climb milling for facing it rapids back to the same side every time. This is okay, except for the final pass this technique rolls over the material and leaves a big burr. Not to mention the lost time spent re positioning to one side after every pass.
